CHESTNUTXE 7,370 Posted November 20, 2015 Here is one i cleaned up from the lot i got at the wreckers Share this post Link to post Share on other sites
matt_lamb_160 252 Posted December 24, 2015 I am jumping in late here, but turboing is not all that cheap unless you do a lot yourself My parts (just from memory, I have never added it up before) Exhaust manifold $50 Intake manifold $350 Intercooler $200 Cooler piping $200 Gas carb $350 Other gas stuff $200 Turbo $900 (Garret) Ignition $400 Exhaust $1500 Waste gate $350 Fittings, hoses and stuff around $400 Engine "reco" $400 (already had a good cam and lifters) Auto $500 (500 HP kit, full manual valve body) + $300 for the auto and stall to start with. Probably more things there. But is reliable and is plenty to scare me. Share this post Link to post Share on other sites
ando76 4,354 Posted December 24, 2015 Forgot to add cheap as std Pistons off some mad crossflow freak from North Queensland. Good to see you back Matt. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted December 24, 2015 Yep, they are the best bit of all!! Thanks Ando Share this post Link to post Share on other sites
CHESTNUTXE 7,370 Posted December 24, 2015 what sought of intake for $350 or is it a blow thru m8. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted December 25, 2015 It is a 4brl manifold. Yes it is blow through. Apart from the exhaust and good wastegate I think I have done it about as cheap as ir can be done wellish. 1 NZXD reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted December 25, 2015 Is it finished matt? come out for a run mines doing daily drive thing atm was drawing all over the place going home this morning Man your zorst cost heaps, its stainless?. how much power you making now?I backed to backed a 4 barrel aussie one over the stock one i ran, it did 6hp over the stock manifold should of wasted 400 bucks on a ice box,,,,, if they had one LOL Share this post Link to post Share on other sites
matt_lamb_160 252 Posted December 25, 2015 Yeah it is finished. Only running 7psi, but is still pretty good and I don't plan on changing it. Should do some time.Still haven't fixed the gaurd though, haha. Yeah, I know. Nope, it is mild steel. External wastegate and cat made it more $$$. Probably should have done it at home, but they did a pretty good job. No idea about tge power. I have thought that about the mani. I run the 4brl as it is easier to mount the carb to. Share this post Link to post Share on other sites
PRO250 1,506 Posted December 25, 2015 Sweet cruise time bring it around ill fix the side and lets go to the ford day in geebongMines at 13atm the valve springs cant keep up at anymore (other engine had springs) I need to change them. my zorst is 3inch stainless my mate did mine I was painting his van and he knew I needed the dump plumbed and ended up making most of the system for It and the turbo drain does the best work to fussyer then I am it was 300 in bits had most of it butwhat did you do for the turbo manifold? just put up pics we want to see its a 425 hey? Share this post Link to post Share on other sites
matt_lamb_160 252 Posted December 25, 2015 There are some pics in the wastegate position thread. Share this post Link to post Share on other sites
