thunderbolt 150 Posted April 6, 2013 no point making 2 threads first the XG it has no spark something to do with moisture because it only happens in damp cool whether I would probably find the problem easy if the manifold wasn't so awful so any help would be good. The XF has parasitic drain that makes the hand brake light glow dimly when engine is off what should i check thanx Share this post Link to post Share on other sites
thunderbolt 150 Posted April 6, 2013 found the problem on the XF Share this post Link to post Share on other sites
Thom 6,654 Posted April 6, 2013 Do you mean spark or park? If spark you ignition module or cap and motor might be dodgy, pull the cap and rotor ( pain in the ass on a xg) and try to wipe it out and spray some crc ot wd40 in there to try and drive the moisture out Share this post Link to post Share on other sites
thunderbolt 150 Posted April 6, 2013 Do you mean spark or park? If spark you ignition module or cap and motor might be dodgy, pull the cap and rotor ( pain in the ass on a xg) and try to wipe it out and spray some crc ot wd40 in there to try and drive the moisture out looks like my finger missed the s key yep i meant spark i tyred the wd40 and found the trigger wheel had a bit of surface rust on it do XGs have TFI similar to the XF EFI Share this post Link to post Share on other sites
SLO247 1,713 Posted April 6, 2013 Yep, same TFI too. Share this post Link to post Share on other sites
KRUPTOR 929 Posted April 7, 2013 Sounds like a bad earth problem in the xf. Share this post Link to post Share on other sites
thunderbolt 150 Posted April 8, 2013 Sounds like a bad earth problem in the xf. its my thermo fan over ride switch is some how doing something (if i turn it on with the engine off the battery don't drain) Share this post Link to post Share on other sites
revhead 1,392 Posted April 19, 2013 coil 1st there a shit of a thing ,leave the tfi until you test replace the coil Share this post Link to post Share on other sites
thunderbolt 150 Posted April 19, 2013 if i disconnect the battery and connect it again it starts (but one of the times i done that i gave it a squirt of ether in the intake ) Share this post Link to post Share on other sites
