Gerry Ahern 366 Posted June 25, 2015 Xb has constant power to wipers, radio, lighter no matter what position key is in. Would people agree that this is very unlikely to be an ignition switch problem but more likely some dick has connected 12 volts directly to something, probably radio? Share this post Link to post Share on other sites
SPArKy_Dave 8,904 Posted June 25, 2015 Doesn't have the original radio in it? Share this post Link to post Share on other sites
SPArKy_Dave 8,904 Posted June 25, 2015 Pull fuses one at a time, and see which one (if any) makes the wipers, etc stop getting power. It could very well be a sticking contact in the ignition switch. Share this post Link to post Share on other sites
Gerry Ahern 366 Posted June 25, 2015 Okay, thanks - so it could be the switch. Share this post Link to post Share on other sites
Ando81 2,950 Posted July 5, 2015 My xf does this randomly, if I turn the key right off sometimes the accessories stay on for roughly 20 seconds. I've heard Toyota echos used to do this from dirty ignition barrels. I've been told to give it a good dose of contact cleaner into the key slot, the same as fixing an echo ignition but thought I better check with someone here first. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 5, 2015 Thanks for that. I am going to take out the barrel and give it a clean 1 Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 7, 2015 Isn't the Accessory switch, one back from engine off position ? Share this post Link to post Share on other sites
Gerry Ahern 366 Posted July 7, 2015 Yes. Looks like switch is faulty Share this post Link to post Share on other sites
revhead 1,392 Posted July 8, 2015 youve got something hooked up and its feeding power back through everything ,disconnet all non standard items ,1 at a time, 1 Outback Jack reacted to this Share this post Link to post Share on other sites
