jamie247 542 Posted December 21, 2014 hi fellow ford lovers, any tips for a quick and easy front windscreen removal, and are the clips easily obtained and correct for fitment Share this post Link to post Share on other sites
jca25 1,034 Posted December 22, 2014 the screen is glued in there is a wire in there if its never bn done before that you put 12v to and it heats it up make it easier to push out or you can use piano wire with to guys to cut it out 1 slydog reacted to this Share this post Link to post Share on other sites
hendrixhc 10,922 Posted December 22, 2014 I just used a piece of wire with a bit of dowell on each end and cut around the screen with a sawing action. As for the stainless trim clips you can get them on ebay or from rare spares. I hope they fit and work ok cause thats what i am going to use. Bigcav might have some more knowledge on them. 1 slydog reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted December 22, 2014 I just got the shop to send a van around to remove the old unit then I checked for where I expected rust to be (found it to be perfect ) and then got him to install the new unit all in the shed @ home. If your screen is in good nick I'd prob still suggest the same as if it's a Ford screen they are hot glued in place and a McFuck to remove all the goup and stuff 1 bear351c reacted to this Share this post Link to post Share on other sites
xbcool 351 Posted December 22, 2014 Yep I'm with rob Get someone else to do it 1 slydog reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted December 22, 2014 Do you want to do it nicely or no fucks given Nicely is the way James has done it. A brick, feet or recipro saw will suffice for the other 1 bear351c reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted December 23, 2014 cheers guys wire it is, the windows front and rear are ratshit anyways i'll be buying brand newies just getting her ready for shell to be sprayed Share this post Link to post Share on other sites
blu xe 825 Posted December 27, 2014 For the price of a new front screen installed there's no way I'd pull and refit an old one in a freshly painted car. A new windscreen looks a million times better and lifts the whole appearance of the car. 2 slydog and jamie247 reacted to this Share this post Link to post Share on other sites
