XFGHIA747 76 Posted May 17, 2014 Hey Fella's now im after the guru that can tell me how to wire my Clevo dissy and coil of the wiring from my efi 6, I have the coil ones word out I think there the same? But the plug from Clevo dissy where do I wire these ? Any help would be good thanks men!. Jake. Share this post Link to post Share on other sites
Anthony Pllu 262 Posted June 24, 2014 i unpluged my coil from my efi250 cut everything else off the loom and droped the clevo in, plugged the coil on and spark right away Share this post Link to post Share on other sites
gerg 10,871 Posted June 24, 2014 Ok is it a 9v or 12v coil? Older points-type dizzys used 9v with a ballast resistor, electronic ones use straight 12V. It will say what it is on the top of the coil. Make sure that you're getting 12V at the coi, as some ignition wires were special resistor wires that had built-in resistance. Establishing that, ignition goes to +, dizzy goes to - and so does tacho if fitted. Share this post Link to post Share on other sites
blownxd393 25 Posted June 25, 2014 If its efi it will be a 12v system already. Share this post Link to post Share on other sites
Grabber 9 Posted October 10, 2014 Any wiring diagrams.? Share this post Link to post Share on other sites
slydog 7,873 Posted October 10, 2014 Check your thread dude... Share this post Link to post Share on other sites
