hendrixhc 10,921 Posted April 25, 2014 So i pulled the master cylinder of the XC today cause its leaking and found out its identical to the XE master cylinder with the 3 ports for lines and 1 port for the switch. This leads me to believe they are compatible. I started up the old girl, just to give her a run, and there was a loud whistling noise coming from round the pin on the booster. If i pushed it back in a bit it stopped. I had a look at the one on the XE and pin appears to be "fixed" in the booster and not free floating like the XCs. This leads me to believe the XC one is stuffed. If memory serves me correctly i had heard that whistle a couple of times while driving. Question is, is the XE and XC boosters the same? If they are ill use the good one from the XE in Lucy for now and look at getting a chrome one for the XE. Other question is does any one know if these chrome boosters are compatible or is there one that has been used in an XE? http://www.ebay.com.au/itm/CHROME-BRAKE-BOOSTER-8-DOUBLE-DIAPHRAGM-CHEV-FORD-HOLDEN-S3908-/250922378027?pt=AU_Car_Parts_Accessories&hash=item3a6c23a32b&_uhb=1 Share this post Link to post Share on other sites
gregaust 319 Posted April 25, 2014 XC + XE boosters are same Share this post Link to post Share on other sites
bear351c 10,273 Posted April 27, 2014 Booster will have to be pulled apart, if you want to get it chromed. ( If you haven't done one before, "dont try this at home" ! ) Sounds like the diaphragm inside is leaking. If you pump the brakes, does the engine change idle?? Share this post Link to post Share on other sites
ronny 204 Posted April 29, 2014 Sounds like vac leak Share this post Link to post Share on other sites
hendrixhc 10,921 Posted April 30, 2014 Got a quote for $320.40 to get the booster rebuilt today by PBR. Anyone know of any other places that do them? ( In Adelaide) Share this post Link to post Share on other sites
bear351c 10,273 Posted May 2, 2014 Kent Brake and Clutch on Port rd. Powerbrakes Holden Hill No idea on $$$. Share this post Link to post Share on other sites
ronny 204 Posted May 2, 2014 Kent Brake and Clutch on Port rd. Powerbrakes Holden Hill No idea on $$$. Kents closed about a year ago 1 bear351c reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted May 2, 2014 Kunts closed about a year ago Fixed! 2 bear351c and ronny reacted to this Share this post Link to post Share on other sites
