ILIED 316 Posted February 19, 2014 Was trying to work out why the reversing lights on the XE weren't working.After spending AGES checking every loom and just plain fucking around by myself, I found that they system DOES work, however they scope of the selector being in reverse is very small. It ll start no wukkas in all the correct positions and inhibit no wukkas in P and N but it just doesnt have fuckall of a window where the backup lights are on. I got the wife behind the car and watched and it was just a flicker, I couldnt manage to keep in in the position that the lights stay on. Anyone got any advice? Share this post Link to post Share on other sites
Gaz 1,085 Posted February 19, 2014 Jack it up, put in reverse (engine off, ignition on) and loosen and twist the switch. When the rev lights come on, lock up the switch and then check all your inhibitor and selector functions. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,895 Posted February 19, 2014 That...... or replace the switch. I've done the odd one or two. Share this post Link to post Share on other sites
bear351c 10,273 Posted February 20, 2014 Agreed. +1. Adjust, or ebay. Common problem. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted February 25, 2014 Easier to adjust if you use a multi-meter under the car set to resistance. You will have infinite resistance until the switch is in the correct position. Share this post Link to post Share on other sites
