XF001 93 Posted October 20, 2013 Just put a t5 in my XF and when driving along in 4th when you take your foot of the accelerator and coast in traffic, there is a whine in 4th gear. It wasn't like this when it was in my other falcon. Any ideas?? Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 20, 2013 at any speed/rpm or all speeds and rpm in 4th? Share this post Link to post Share on other sites
XF001 93 Posted October 21, 2013 While the gearbox is under load (driving along) there is no noise. It only comes out when you remove your foot off the accelerator and coast like when you are approching a red light and it is only in 4th gear. It doesn't matter what speed you are doing Share this post Link to post Share on other sites
gerg 10,871 Posted October 21, 2013 That's very strange considering 4th is the only "gear" that is direct drive (no gears actually involved), so there should be no force on the gearset or the bearings in 4th, thus no noise. Have you ruled out the diff? Share this post Link to post Share on other sites
XF001 93 Posted October 21, 2013 I assumed it was the gearbox because I don't remember hearing the noise while it had an auto box in it. Share this post Link to post Share on other sites
Stevemack 122 Posted October 21, 2013 Did you put in a new spigot? Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 21, 2013 Sounds kinda like forked bearing in the gearbox but that is unusual for 4th... You could try dropping your box oil and checking the color, Then stick a good strong telescopic magnet in the box and drag it out, see if you pick up a heap of shit with it. 1 Thom reacted to this Share this post Link to post Share on other sites
XF001 93 Posted October 22, 2013 Put in new spigot and oil is brand new. New clutch, pressure plate and throw out bearing. I only noticed the noise on Saturday. I will have to jack the car back up and recheck the oil level in the gearbox and check the diff as well. The oil that came out of the box when I removed it from my other XF was a good colour as well. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 23, 2013 Did you use dexIII in the box? Share this post Link to post Share on other sites
XF001 93 Posted October 23, 2013 Used Dex11 ATF as per the service manual. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 23, 2013 Good stuff. Let us know what you find. Share this post Link to post Share on other sites
