RAWDEAL 222 Posted September 29, 2013 http://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns#Later_Windsor_V8_pattern best link ive found in a while!! Wondering if the later model aussie 6s fit with anything else on this list or are they there own pattern? id love to update the wiki! AFAIK late EL/AU/DOHC are the same, but different to SOHC? SOHC is ???XFLOW is SBF? Share this post Link to post Share on other sites
RAWDEAL 222 Posted September 29, 2013 we have this resource can be seen http://www.operabrow.com/ Russian opera browser website lol? Share this post Link to post Share on other sites
Thom 6,658 Posted September 29, 2013 xp-xf 6 cyl are the same as each other, ohc from ea to El are the same Au to bf (unsure of fg) 6 cyl are the same (ea bf are interchangeable but the supports at the bottom of the bellhousing don't line up as Au on used a cast aluminum sump instead) Share this post Link to post Share on other sites
RAWDEAL 222 Posted October 7, 2013 xp-xf 6 cyl are the same as each other, ohc from ea to El are the same Au to bf (unsure of fg) 6 cyl are the same (ea bf are interchangeable but the supports at the bottom of the bellhousing don't line up as Au on used a cast aluminum sump instead) So basically OHV xp-xf Are the same, and the same as SBF? OHC Ea-El are the same pretty much 100% OHC/DOHC Au-BF Are the same OHC/DOHC Ea to BF are the same except those alloy gusset things that they use dont line up? What about 250xflow to Ea OHC? Share this post Link to post Share on other sites
Thom 6,658 Posted October 7, 2013 xp-xf 6 cyl are the same as each other, ohc from ea to El are the same Au to bf (unsure of fg) 6 cyl are the same (ea bf are interchangeable but the supports at the bottom of the bellhousing don't line up as Au on used a cast aluminum sump instead) So basically OHV xp-xf Are the same, and the same as SBF? OHC Ea-El are the same pretty much 100% OHC/DOHC Au-BF Are the same OHC/DOHC Ea to BF are the same except those alloy gusset things that they use dont line up? What about 250xflow to Ea OHC? Almost v8 is differed to 6cyl and ohc is different to xflow Share this post Link to post Share on other sites
RAWDEAL 222 Posted October 20, 2013 Almost v8 is differed to 6cyl and ohc is different to xflow Fk ford sometimes! how hard would it be for them to make the patterens all the fkn same! lol just want to convert an earlier car to OHC now i cant use any decent gearboxes ! Share this post Link to post Share on other sites
78xcgxl 241 Posted November 3, 2013 Fk ford sometimes! how hard would it be for them to make the patterens all the fkn same! lol just want to convert an earlier car to OHC now i cant use any decent gearboxes ! 4 speed autos on ea- au are good and T5s are good as well, what is the problem? Share this post Link to post Share on other sites
Thom 6,658 Posted November 4, 2013 The gearboxes that come behind a 4.0l are well up to the task of handling a hot 4.0l what gear box did you want to put behind one? 1 78xcgxl reacted to this Share this post Link to post Share on other sites
bear351c 10,277 Posted November 4, 2013 Try Dellow Automotive. They used to make bell housings etc...... http://www.dellowconversions.com.au/about.html Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 6, 2013 The gearboxes that come behind a 4.0l are well up to the task of handling a hot 4.0l what gear box did you want to put behind one? I was either gonna use the c10 i have sitting in the shed.. or the 6 speed manual i also have sitting in the shed lol. ive got a forward shifter mount kit for it to Share this post Link to post Share on other sites
Thom 6,658 Posted November 6, 2013 Dellow and torque power make a bellhousing to fit 4.0 to c10 Share this post Link to post Share on other sites
78xcgxl 241 Posted November 6, 2013 Go manual, non overdrive autos are boring and only good on the drag strip! What is the 6 speed you have? Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 10, 2013 Go manual, non overdrive autos are boring and only good on the drag strip! What is the 6 speed you have? its a tr6060, i have a bellhousing to suit a clevo , is why i was annoyed to find the 4.0 doesnt share the same pattern Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 10, 2013 its a tr6060, i have a bellhousing to suit a clevo , is why i was annoyed to find the 4.0 doesnt share the same pattern Actually might sus out and see if my mod motor/tr6060 bellhousing fits the Au or the eb OHC motors i have laying around.. might get lucky and it fits one of them lol Share this post Link to post Share on other sites
Thom 6,658 Posted November 10, 2013 Starter clearance is probably your main issue even if the bolt holes line uo Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 24, 2013 Starter clearance is probably your main issue even if the bolt holes line uo Yeah should fit ok with a bit of ball peen persuasion haha Share this post Link to post Share on other sites
Thom 6,658 Posted November 24, 2013 using a 6 cyl bell housing on a v8 wouldn't work as the starter would be positioned behind the cyl head and they are an entirely different bolt pattern Share this post Link to post Share on other sites
RAWDEAL 222 Posted December 3, 2013 using a 6 cyl bell housing on a v8 wouldn't work as the starter would be positioned behind the cyl head and they are an entirely different bolt pattern Yeah its a bit annoying lol If the bolt pattern was the same as say SBF or something more common i could more than likely order a Quicktime bellhousing with the starter in a different spot It being it has its on unique pattern makes things annoying Share this post Link to post Share on other sites
