iamaelephant 35 Posted February 9 Another day another problem. I'm trying to get a new oil pan onto my 351C and the engine mounts are interfering with the flange of the sump, preventing it from fitting. Is this a case of cheap engine mounts that are incorrectly shaped or what? See these pictures, notice how the engine mounts curve inwards toward the flage. Are they supposed to look like this? In case you're wondering how the old oil pan fit, the flange has been damaged by the engine mounts and it was very difficult to remove. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted February 9 yes i have had that problem a few times with after market mounts,just grind them back a bit to give a little clearance,i also got 1 mount that was made upsidedown yeah it still bolted on but looks a bit like the first picture you have,something dont look right there. 1 gregaust reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted February 12 Looks like the weight of the engine is pushing the 2 mounts in towards each other. When they're bolted in they tend to "hang" spreading apart. As Chestnut said, the aftermarket Clevo sumps can be a bad fit, I've fitted a couple, and had to trim, grind, elongate holes etc. It's just symptom of the non genuine market. Got an old original sump you can slide in, just to see if it fits better.?? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,910 Posted February 13 The top pressed metal part of those engine mounts, looks a bit thin tbh. Do you have any original mounts to compare with? Share this post Link to post Share on other sites
iamaelephant 35 Posted February 13 I don't have any OG mounts on me right now, but I have some new mounts on order which should arrive in the next day or two. As it happens I am the one who installed the current mounts and I have some photos of them next to the ones I pulled out. To my eye they do look a millimeter or two thinner than the original ones, what do you think? They came from a reputable company but I suspect I bought some chinese junk here. The new sump is an Aeroflow, I've always had good luck with them as a brand. Share this post Link to post Share on other sites
SPArKy_Dave 8,910 Posted February 13 Those new mounts look pretty bad, in comparison to ur originals. The angle of the upper tabs, is way different! What brand are they? ie - Mackay, Kelpro etc 1 iamaelephant reacted to this Share this post Link to post Share on other sites
iamaelephant 35 Posted February 13 Transgold https://www.maceengineering.co.nz/epages/macenz.sf/en_NZ/?ObjectPath=/Shops/macenz/Products/MNT836-D 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,910 Posted February 13 Choices seem to be the following - Mackay - A1140 Kelpro - MT8095 Pioneer - 602257 Transgold - MNT836 I've also read, u can get new rubber vulcanised to the old metal pieces. 1 iamaelephant reacted to this Share this post Link to post Share on other sites
iamaelephant 35 Posted February 13 I have Pioneer 602257 mounts on their way now, I'll let you know if they look any better. 2 SPArKy_Dave and bear351c reacted to this Share this post Link to post Share on other sites
iamaelephant 35 Posted February 19 Here's a comparison of the old (only less than 2 years old) mounts to new ones. The old ones folded severely at the bend. I don't know what caused this and I hope it doesn't happen again. The new ones are 0.5mm thicker so not very much. Now that the new mounts are fitted I need to get the oil pan on and it is really fighting me but I'll get there. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,910 Posted February 19 Big difference between the old (transgold?) and new (Pioneer?) mounts! Do u still have a factory Ford mount, to compare metal thickness? Share this post Link to post Share on other sites
iamaelephant 35 Posted February 19 Correct on the brands. Unfortunately no I don't have an OEM mount, but if anyone does I'd love to see a measurement. My pioneer mounts are 4.5mm thick. Share this post Link to post Share on other sites
iamaelephant 35 Posted February 20 I really can't believe this, I'm so annoyed. I was very careful with the gasket install (I followed Clevo King's excellent video). Everything seemed good until the final torquing (just 12 ft lb) and the gasket split in the corner. This sump install on the garage floor was such a massive pain, at this point I think I'll just live with the damn leak for a year until I can be bothered to do it again (or if I decide to pull the motor at any point). Any idea what I could have done to avoid this? 1 1 CHESTNUTXE and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted February 20 I've also used many areoflow sumps and all were good,but I have always had the engine on the stand upside-down and fitted the sump with tiny increases on doing the bolts up to stretch the sump at all angles,then let it sit overnight and re torque again to spec until it seals on the sweet spot,squeezeing out the gasket is common,but not spliting like that,possibly a sharp spot or something? Share this post Link to post Share on other sites
SPArKy_Dave 8,910 Posted February 21 Wow, what a pain! I've had gasket failure happen, mostly with 3spd BW Auto trans pans. I usually spray cork gaskets with Hylomar sealant, but found if I coat it too much without drying properly first, the gasket goes soft and breaks My factory XB service manual says 7-9ftlb for the smaller pan bolts, and 11-13ftlb for the larger ones at the end. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
