Searley 143 Posted April 22, 2023 Hello Fordys, My XH Ute sometimes won't start straight up sometimes and I find that pulling in the column shift lever and moveing it up & down Will Engage the Starter and it will start. I've heard that this is"The Inhibitor Switch" located off the side of the Auto Trans. Does it mean it needs cleaning or is it advised to get a New One? Thanks Have a Great Day, Share this post Link to post Share on other sites
deankxf 20,294 Posted April 22, 2023 22 minutes ago, Searley said: Hello Fordys, My XH Ute sometimes won't start straight up sometimes and I find that pulling in the column shift lever and moveing it up & down Will Engage the Starter and it will start. I've heard that this is"The Inhibitor Switch" located off the side of the Auto Trans. Does it mean it needs cleaning or is it advised to get a New One? Thanks Have a Great Day, if you couldn't find a new one you could probably remove it and submerge it in kero/petrol etc and rotate it through the range several times and it would probably be fixed. also, if you were anything like Me, you'd just go park to 1st back and forth like 50 times and it may be fixed (or worse) but i don't think the are serviceable if anything like the prior models , so buy either a used one or new one if available and likely last another 25yrs Share this post Link to post Share on other sites
Searley 143 Posted April 22, 2023 Thanx for that deankxf, I have'nt got Arms like Hercules but I thought I'd Better do something about this before I Bent the column. As you can see on e-bay you can still get them @ different $prices and some new or pre-used. Some advertized as Genuine Ford but 2nd hand Hmm. I'll try New.FNS012 INHIBITOR SWITCH for FORD FALCON XG XG XR6 XH I XH I XR6 XH II XH II XR6 9314258726638 _ eBay.htmlFORD EA EB ED EF EL XG XH AU STARTER INHIBITOR & REVERSE LAMP SWITCH EXC COND _ eBay.htmlFORD FALCON EA EB ED EF EL AU XH FAIRMONT NA NC NF NL INHIBITOR SWITCH GENUINE _ eBay.html Share this post Link to post Share on other sites
Fingers 463 Posted April 22, 2023 I would check the adjustment first 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,294 Posted April 22, 2023 12 hours ago, Fingers said: I would check the adjustment first @Searley this is possible (likely) if the bushes/gates in the gearshift assy are a bit worn. definitely worth checking. 1 Searley reacted to this Share this post Link to post Share on other sites
Thom 6,651 Posted April 23, 2023 You can adjust them by checking continuity with a multimeter while moving it, they don't have a lot of movement but they have enough to be adjusted back to working at times 1 1 deankxf and Searley reacted to this Share this post Link to post Share on other sites
Searley 143 Posted April 23, 2023 Hello Fordy Mates, Thanks for the Tips, I'll have a Look tomorrow and Try it out. Cheers. 1 deankxf reacted to this Share this post Link to post Share on other sites
