Julian 2 Posted November 19, 2022 G'day, I have major rust problems with the bonnet hinge/ tracks in an XH ute. I've tried to attach photos but having problems uploading. The hinge point and track on the right hand side has...... dissapeared. The hinge brackets that attach to the bonnet itself are fine. Wondering if there are parts available to replace? Seems like I may have to make a new one. The left hand one seems to be fine so could use it as template. Any ideas would be greatly appeciated! Share this post Link to post Share on other sites
SPArKy_Dave 8,913 Posted November 20, 2022 Sounds like plenum chamber rust? Common on earlier x-series, but not often seen on XH's... yet. @deankdxcan advise about uploading pictures Share this post Link to post Share on other sites
deankxf 20,356 Posted November 20, 2022 On 11/19/2022 at 6:26 PM, Julian said: I've tried to attach photos but having problems uploading On 11/19/2022 at 6:26 PM, Julian said: the hinge point and track on the right hand side has...... disappeared. usually if that track as rusted away you''l have water leaking on the floor due to rust in the wiper plenum as sparkydave mentioned above. it could be just bent, you can probably stick a torch/camera in the wiper vent and see if it's there or not. link below to upload photos Share this post Link to post Share on other sites
