Squiz 20 Posted October 30, 2022 Hi all, ive just aquires a 92 xf ute of my uncle and the drivers door wont open no matter what we do, door hands not boken its unlocked aadn the inside handle works, i managed to get the door trim off but cant seem to see the problem, anyone had this happen before? really have no idea what to do to get it open. Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 FIRSTLY, try turn the key to UNLOCK and hold it in that position, if the handle works to open the door then it will confirm what i'm expecting same could be done with the window down and holding the lock button up. if you lift the handle and notice the lock button dropping, then it's what i suspect above. there's a broken spring in the door actuator check that first and i'll see if i can google a pic for you. 1 Squiz reacted to this Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 if it's as above, and you find in the bottom of the door bits of this spring.. it's the issue link to one here, i've never bought one or fitted it, only just bought a good used mechanism and swapped it. https://www.custommustangs.com.au/ford-falcon-door-lock-mechanism-repair-spring-xd-x this isn't the cheapest it's just the first one that popped up with google 1 Squiz reacted to this Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 when i hold he handle up the door lock doesnt go back down but i did see a spring like that on the floor of the ute Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 so how do i get the door open to be able to replace the mechanism? Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 if it is that spring can it be replaced while the doors still stuck shut? Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 so the inside handle doesn't work either? Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 yes it all works nothing looks broken it just wont unlatch for some reason Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 i made these videos for someone 11yrs ago with a similar issue, it's all i can do at the moment. (no more falcons) 1 Squiz reacted to this Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 Just now, Squiz said: yes it all works nothing looks broken it just wont unlatch for some reason just posted 2 videos, SPRAY it all with WD40 or CRC etc and keep trying if it's all connected still try make sense of the videos, the lady i made them for figured it out from them. 1 Squiz reacted to this Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 thankyou, i coated it all in CRC before i left this morning ill be able to go back to it next weekednd and have another go with these videos as reference. hopefully i get the dam thing open atleast dont mind if i have to buy a new mechanism Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 2 minutes ago, Squiz said: thankyou, i coated it all in CRC before i left this morning ill be able to go back to it next weekednd and have another go with these videos as reference. hopefully i get the dam thing open atleast dont mind if i have to buy a new mechanism it could be just stiff in the latch(door out of adjustment due to stuffed hinges/cracked door near hinge) if so, give the door from the inside some decent push pull action while holding the handle open(don't force the handle, that's not the issue unless something else is broken, forcing the handle will break something 99% of the time) Share this post Link to post Share on other sites
Squiz 20 Posted October 30, 2022 yeah tried that i was in the ute using my feet to push against the door while my uncle was trying to get it open but that didnt work either Share this post Link to post Share on other sites
deankxf 21,709 Posted October 30, 2022 27 minutes ago, Squiz said: yeah tried that i was in the ute using my feet to push against the door while my uncle was trying to get it open but that didnt work either you might need to do what's in one of the videos, line up the lock part (you'll see what the lock button does) then lift the pin with a screw driver. i've only had this happen once personally and someone else had it so i made the video for them. i think the door mech was just full of dust mainly, i don't recall there being anything broken in it in this case. that spring in the bottom of the door is usually from previous broken door handles if it's thicker spring metal. bigger also. you'll be able to see it on the handle easy enough. Share this post Link to post Share on other sites
SPArKy_Dave 9,483 Posted October 31, 2022 These days, it's usually the outer door latch mechanism, that seizes up. Especially with x-series which have been sitting. (higher chance of sticking, if exposed to the weather also) I've encountered the above problem, multiple times now - dealing with aged XD-XF's. I've personally not had any real luck yet fixing the problem apart from removing door trims (and also pinch-weld seals - to better expose the stuck outer mechanism)... then drowning the inner and outer mechs with a Penetrene/WD40/CRC type spray. Sometimes they've come loose after doing that, and sometimes not. I've got one rear door and one front door - still stuck after 12mths. Moving forward, I would be inclined to pack the outer mech's with a general purpose zinc or lithium grease or similar lubricant - a grease which won't degrade small plastic or nylon parts, which may be present inside the latch mech. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,709 Posted October 31, 2022 1 hour ago, SPArKy_Dave said: These days, it's usually the outer door latch mechanism, that seizes up. good point, i haven't had many with this issue but i did have one (partly mangled due to door misalignment from broken door hinge) i had a feeling i undid the hinges off the pillars to get more wiggle on the latch and striker. might be something to try next. Share this post Link to post Share on other sites
Mick.G 48 Posted April 16 That little spring is what is missing ,Driver's door never could be opened from outside since i got it . Got some arriving today . This thread made me happy. 1 1 SPArKy_Dave and deankxf reacted to this Share this post Link to post Share on other sites
Mick.G 48 Posted April 18 Cant see which way the spring gets installed in that video ! Have tried to install and no luck. Share this post Link to post Share on other sites
deankxf 21,709 Posted April 18 19 minutes ago, Mick.G said: Cant see which way the spring gets installed in that video ! Have tried to install and no luck. there's a hole either side in a gap, it just needs to have one of the spring parts in each side.. bit of a fiddle to get it in there. found a photo of it on ebay. edited it to show where it goes. Share this post Link to post Share on other sites
Mick.G 48 Posted April 18 Thought this was the case..After checking passenger side mechanism i discovered me spring gauge was too thick and impossible to get it to fit. squashed the spring in vice grips and forced it in and now it works. My Dickheadness for getting the wrong spring. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,709 Posted April 18 1 hour ago, Mick.G said: Thought this was the case..After checking passenger side mechanism i discovered me spring gauge was too thick and impossible to get it to fit. squashed the spring in vice grips and forced it in and now it works. My Dickheadness for getting the wrong spring. at least you can get them now. back when i was playing with this old stuff, it was off to the wreckers for a whole lock mech.. with ford parts saying NLA (no longer available) for anything you ever wanted. (plus side back then, you could buy a whole car for $500 or less and get 3 or 4 of those springs and a host of other spare parts) Share this post Link to post Share on other sites
Mick.G 48 Posted April 19 19 hours ago, deankxf said: at least you can get them now. back when i was playing with this old stuff, it was off to the wreckers for a whole lock mech.. with ford parts saying NLA (no longer available) for anything you ever wanted. (plus side back then, you could buy a whole car for $500 or less and get 3 or 4 of those springs and a host of other spare parts) The mechanism was dirt as Fk , so took it out to clean and install new spring.after a good clean noticed the wear and will keep a eye out for a better/newer one ,Working like new at the moment ,But know that wont last. Share this post Link to post Share on other sites
deankxf 21,709 Posted April 19 1 hour ago, Mick.G said: ,Working like new at the moment ,But know that wont last it probably will work like new for ages now. i submerged an XG mech (same as e series) in petrol and swished it around, was absolutely caked in dusty grease. worked mint afterwards. i'd just spray it with WD40 or similar and it's probably good for another 10+ years if it's working fine now. 1 Mick.G reacted to this Share this post Link to post Share on other sites
