RM351 148 Posted February 19, 2022 Not having much luck finding a pan fill C4 (my first preference) on the west side. The FMX would be the next choice however, I already bought a new TCI shifter suitable for C4/C6 as well as a neutral switch. As you all know there is no aftermarket bits for the FMX, so the next choice would be the C6 but, is it a straight fit and is it too big on HP robbing compare to a FMX? Engine will be a mild 351 (not using for drag racing etc) with a possibility of going to a 393 or 408 down the track. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted February 19, 2022 you could go either way,and yes c4s are now getting very pricey for a core,once upon a time c4 panfils were everywhere and $200 got you a good starting point ,the c6 is ok ,i fitted one to my old 400 in the xf ute and bolted in easy,fmx has same yolk 31 spline,and is a little bit heavier,also generaly extractors fit c4 or fmx,but c6 might need a custom set. 1 RM351 reacted to this Share this post Link to post Share on other sites
RM351 148 Posted February 19, 2022 3 hours ago, CHESTNUTXE said: c6 might need a custom set. Crap...probably need to sell one of my organs to pay for a custom job. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted February 19, 2022 Been told Pacemakers for a Clevo interfere with an FMX trans, not sure about C6. Some listings on Fleabay specifically say ..."not suited to FMX" 2 CHESTNUTXE and RM351 reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted February 19, 2022 I retract that last statement.......... Pacemaker list PH4055 and say in red letters WILL fit C6 and FMX. Maybe it's their 4 into 1's I was thinking about. Yep, thats it Castle headers, CH112A. 2 RM351 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted February 20, 2022 you will need a flexible dipstick on a c6 as no aussie cars came with c6,or maybe a mustang c6 one might work,also you will need to make trans lines up for a c6,at the end of the day all three gearboxes will work fmx can be had very cheap,and is a dam strong gearbox ,only downside is weight and ya need 31 spline yoke and new uni to mate it too ya tailshaft,but if ya already bought a shifter keep looking for a c4 pan fill ,its light,everything fits,and then lay down a rubber road. 1 RM351 reacted to this Share this post Link to post Share on other sites
RM351 148 Posted February 21, 2022 The shifter I have has the bracket for a C6 plus I have a 31 spline yolk so I could go either C4 or C6. I wanted to make sure the C6 is not overkill in weight or power robbing compared to a FMX if I choose to go with that. Share this post Link to post Share on other sites
gregaust 319 Posted February 21, 2022 Any of those are an ok option for a mild setup . Don't get caught up in the whole HP robbing thing. For your setup you'd never notice. Anyway a roller bearing in a C6 at the rear helps free them up and available as a bolt in deal . The C4's are around but pricey . If you're rebuilding budget in for a planet as most are worn out . The C6 is tough as as long as the pipes will fit as above . The right parts and a shift kit help nicely. And a tube dipstick will fit in a Falcon no problems . The FMX with a good rebuild and transgo shift kit is all it will need . As long as it is ok parts wise to start with , and pay attention to the forward drum bore where the sealing rings run . A lot are worn but can be sleeved . FMX + C4 are same length so tailshaft will fit with correct yoke . C6 likely need tailshaft shortened 1 1 RM351 and bear351c reacted to this Share this post Link to post Share on other sites
