bear351c 10,433 Posted November 23, 2020 Air, spark, fuel.......... Blocked air filter? Throttle body jammed? Any progress, mate? 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 21,113 Posted November 23, 2020 1 hour ago, bear351c said: Throttle body jammed? kinked throttle cable(not getting full throttle) Share this post Link to post Share on other sites
Dirtyxhute 39 Posted November 23, 2020 Hey boys,Cleaned throttle body right out, getting full range on it, everything seems to be fine.Cleaned the air box, and replaced the element. No blockages. There’s something simple that I’m missing surely.Sent from my iPhone using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted November 23, 2020 Fuel filter, under ute, passenger side, just behind the door. Change that and see how you go.Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
Dirtyxhute 39 Posted November 23, 2020 Fuel filter, under ute, passenger side, just behind the door. Change that and see how you go.Sent from my S21 using TapatalkWill do, will report back with an update Sent from my iPhone using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted November 23, 2020 Will do, will report back with an update Sent from my iPhone using TapatalkUse some WD40 on the threads to loosen the filter up a bit, they get pretty dusty under there.Mine was being a gutless pig awhile back, ended up being blocked/dirty fuel filter.Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
