XD Falcon ute 0 Posted July 9, 2020 Hi this might be a dump question, i bought my grandson a Xd ute it has a 3 speed auto column shift it's a project for the 2 of us my question is the young fella wants to put a 4 speed auto in can someone tell me what gearbox we need cheers Share this post Link to post Share on other sites
gerg 10,875 Posted July 9, 2020 4 speed will be a shifter & leverFlywheelFlywheel boltsClutchForkCableManual pedal box with clutch pedal Clutch cable firewall mount bracketGear shift surround/tunnel housingManual consoleProbably forgot something Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
deankxf 21,128 Posted July 9, 2020 43 minutes ago, XD Falcon ute said: my question is the young fella wants to put a 4 speed auto in can someone tell me what gearbox we need cheers you won't need a 4 speed auto, unless it's got lower diff gears(unlikely if it came as an auto will be 2.92 ratio. if the 3 speed auto is good, leave it in there.(a stronger upgrade if you can find one is a C4 auto some of the 6cylinders had, rare even 10yrs ago) 4 speed autos are only on the overhead cam engines, different bolt pattern to the engine, and need a computer as they are electronic. and wouldn't work well with the current diff ratio either. (they only had 3.08, 3.23/3.27) from memory. it will sit on 2300-2400 ish rpm at 100kmh all day every day forever at that. if you decided to modify it, then you'd look at a driveline from a donor vehicle(barra from BA onwards etc is popular these days.. but it's not easy and i wouldn't do it) i'd stick with the crossflow personally.. good reliable SIMPLE engine, can change a starter motor in 4 minutes and an alternator in not much more time 1 roKWiz reacted to this Share this post Link to post Share on other sites
gerg 10,875 Posted July 9, 2020 Sorry I read that as "4 speed" and didn't see the auto bit. Disregard Sent from my CPH1607 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted July 9, 2020 58 minutes ago, gerg said: Sorry I read that as "4 speed" and didn't see the auto bit. Disregard Sent from my CPH1607 using Tapatalk i saw your post after i replied with mine, forgot to even mention it.. more info for the next person asking anyway 1 gerg reacted to this Share this post Link to post Share on other sites
