Rodders 16 Posted May 11, 2019 How do you get the door hinge bolts back from inside A Pillar?I can’t even see them. The bottom ones. Yoiks!!! Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
2redrovers 21,404 Posted May 11, 2019 Have you taken the inside kick trim off? Share this post Link to post Share on other sites
Rodders 16 Posted May 11, 2019 Have you taken the inside kick trim off? No, does that help?Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
2redrovers 21,404 Posted May 11, 2019 If something fell inside a pillar and it went straight down, should be able to access from behind the trim. Not hard to check, think there's only two screws/clips 1 Rodders reacted to this Share this post Link to post Share on other sites
Rodders 16 Posted May 11, 2019 If something fell inside a pillar and it went straight down, should be able to access from behind the trim. Not hard to check, think there's only two screws/clips I’ll give that a go when I get a chance. Thanks.Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
deankxf 20,339 Posted May 11, 2019 38 minutes ago, Rodders said: I’ll give that a go when I get a chance. Thanks. Sent from my iPad using Tapatalk yes there's a hole you can fit your hand in(check for redbacks) the 3 bolts are on a plate that rests on a hook. if you can stick the phone camera over the hole you'll see what it looks like. i hadn't lost one in there, but i removed one to replace one with a broken stud once. should be fairly easy once the kick panel trim is off and the sound deadening matt removed 1 Rodders reacted to this Share this post Link to post Share on other sites
