Danielbw 0 Posted October 15, 2018 I can get a NC Fairlane lsd diff from a wreckers, will it fit a eb falcon both are sedans if it will would it also fit an ef or au? and if it won't what else would I have to take to make it fit? Share this post Link to post Share on other sites
hendrixhc 10,920 Posted October 15, 2018 Will fit the eb. E.g. maybe with some brake line mods but I think e.g. had larger brake rotors. Won't fit au. Share this post Link to post Share on other sites
deankxf 20,288 Posted October 15, 2018 depends if it's series one or 2 for both EB and NC fairlane. but if the are both same it's direct fit. exact same.. the only difference will be if one is series one, the other series 2 the lower control arms are wider on Series 2. you can change the bushes to suit on one end of the lower control arms to suit.. or if your car is a series 1 and you fit a series 2 diff you can just pack out the difference with big steel washers like a tow bar has EF has different brakes and series 2 style lower control arm bush.. AU is a wider diff with EF style brakes.. would probably still bolt in but you'd be mucking around a fair bit 2 Danielbw and bear351c reacted to this Share this post Link to post Share on other sites
Danielbw 0 Posted October 16, 2018 Any idea how to identify if NC Fairlane is series 1 or 2? 👍 Share this post Link to post Share on other sites
deankxf 20,288 Posted October 16, 2018 12 hours ago, Danielbw said: Any idea how to identify if NC Fairlane is series 1 or 2? 👍 might say in here.. year made? i can't be bothered reading ithttps://en.wikipedia.org/wiki/Ford_Fairlane_(Australia)#NC_/_DC_(1991–1995) Share this post Link to post Share on other sites
