``` 54 Posted September 7, 2018 Can anybody tell me how much movement there should be on a mechanical fuel pump? The one on my sons 81 xd 4.1 looks like it is the original and I am not sure if it's working properly. The video shows how much movement there is of the 'arm'..just not sure if it should more or if it looks right? cheers. 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,294 Posted September 7, 2018 video link doesnt work for Me Share this post Link to post Share on other sites
``` 54 Posted September 8, 2018 anybody else having trouble viewing it? I have re-posted and hopefully it works now (works for me by the way) Share this post Link to post Share on other sites
bear351c 10,271 Posted September 8, 2018 Nope, cant see it, just a photo. I use Flickr as well, says your vid is private. Share this post Link to post Share on other sites
bear351c 10,271 Posted September 8, 2018 They dont do much, only about 4-6 PSI of pressure, you can plumb up a line into a jar of fuel, and pump it by hand. If no fuel comes out through the "arm hole" the diaphragm should still be good. If it gets wet at all, its prob got a ruptured diaphragm, and needs a newie. Not sure if you can still find an overhaul kit, for these. Especially in Kiwi country. May have to buy a whole pump.... Share this post Link to post Share on other sites
``` 54 Posted September 8, 2018 17 hours ago, bear351c said: says your vid is private. bugger..didn't realise it was set as private! have sorted it now. When I removed it from the car it still had fuel in it and I could pump fuel out of it so assume it is ok? Share this post Link to post Share on other sites
deankxf 20,294 Posted September 8, 2018 i recall them having more movement.. but then again, it's been 10yrs since i have had one Share this post Link to post Share on other sites
bear351c 10,271 Posted September 8, 2018 reckon all that slop would be taken up when you install it. Usually have to push the arm in to get it to seat against the cam lobe. Share this post Link to post Share on other sites
``` 54 Posted September 10, 2018 What are the Fuelmiser pumps like? Does anyone make replacement in tank sender units for the xd? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted September 10, 2018 What are the Fuelmiser pumps like? Does anyone make replacement in tank sender units for the xd?Fuelmiser is just a box, they don't make anything. They buy other companies parts and put them in a Fuelmiser box, so you could end up with a cheaper no name part, or something made by someone like VDO Share this post Link to post Share on other sites
``` 54 Posted September 10, 2018 11 hours ago, Mr Polson said: 12 hours ago, ``` said: What are the Fuelmiser pumps like? Does anyone make replacement in tank sender units for the xd? Fuelmiser is just a box, they don't make anything. They buy other companies parts and put them in a Fuelmiser box, so you could end up with a cheaper no name part, or something made by someone like VDO Do VDO still make them? Share this post Link to post Share on other sites
deankxf 20,294 Posted September 10, 2018 if you can't find the fuel sender this might be worth looking at Share this post Link to post Share on other sites
