Kiwi-E 731 Posted April 4, 2018 Anyone had experience adjusting or overhauling a power steering box? Or have a link to a workshop manual for one? Just thought I'd ask before i have a go at adjusting mine. Cheers Sent from my SM-J500Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted April 4, 2018 just beware if you undo the top cover grub screw(allen key) theres like a 80% chance that thread will strip.. (fairly sure this is the "fine adjustment" ) and the other adjuster is inside the wheel well. i've only done the fine one. if you decide to do that, i'd suggest removing the cover, removing the o ring, heating it with a blow torch or heat gun etc and possibly spraying cold spray on the grub screw then removing the grub screw.. then reassemble and adjust.. it could be the case that the top cover is worn and this is not going to fix the issue, there are some with bearings fitted, some relying on just the alloy.. so you may need a top cover anyway. i wouldn't mess with it without spares or taking precautions cant find it on ebay anymore, found a thread that mentions something on it.. https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQFpi_YzF8I0-vqtjVlZGrjfIRWmVmp2lbf-P3W1GPDOPnP6Way 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Kiwi-E 731 Posted April 5, 2018 Cheers Dean. I've got one box that binds quite badly and one supposedly good box but it has a fair bit of play. I might strip the binding box down or have a crack at adjusting it before touching the 'good' boxSent from my SM-J500Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted April 5, 2018 2 hours ago, deankdx said: it could be the case that the top cover is worn and this is not going to fix the issue, there are some with bearings fitted, some relying on just the alloy.. so you may need a top cover anyway. The early tops have a bronze bush, pressed into the alloy top. And the later tops, had a torrington race roller bearing. 3 deankxf, Outback Jack and Kiwi-E reacted to this Share this post Link to post Share on other sites
