ICEWOLF 53 Posted September 30, 2017 Been looking at hoses, leads and plugs for the XE and wondering why the XFs have different parts. Weren't the EFI XE and EFI XFs much the same engine and engine bay wise? If not any one know what the differences were? Share this post Link to post Share on other sites
deankxf 20,288 Posted September 30, 2017 dissy cap and leads were different style on XFs, couldn't tell you what else.. you could use the XF cap and leads(need the spacer from XF also, and leaded XF rotor button) if XE stuff is unavailable? not many know what a leaded XF rotor button is either though. Share this post Link to post Share on other sites
ICEWOLF 53 Posted September 30, 2017 Is it worth switching over to the xf style cap and leads? Could do it if it's a better design since I am replacing both at the same time. Don't know about the spacer you mentioned though. Where does that go? The heater hoses being different was the main one I was concerned about as I will have to order them in since no one stocks them these days. Don't want to end up with the wrong ones Share this post Link to post Share on other sites
Mr Polson 10,214 Posted September 30, 2017 XE used a Bosch Jetronic fuel injection system, it was very simple with no distributor control, and mechanical operation of things like the fast idle.XF got Ford's EEC4, a Ford injection system based on what was being used in the states. Much more was controlled by the computers including distributor advance, fast idle/air bypass settings etc.Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted October 1, 2017 i'd keep it simple and use the XE leads and cap..and rotor button the XF had a 2 part dissy cap, probably to make it easier to get it out from under the inlet manifold with the taller post terminals. haven't heard of one being better than the other. only reason i have ever switched is because i wrecked a car that had new cap and leads prior to being wrecked Share this post Link to post Share on other sites
