1977 ZH 540 Posted April 17, 2013 Just wondering if anyone here has used a mega squirt with eec4 adapter? i purchased one off a member on here. Is there any additional items i need before i start getting it set up? id prefer to have everything i need instead of having to chase things up. Cheers. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 17, 2013 Did you read the instructions on DIY autotune? At a minimum You will need an IAT sensor. You can use your factory coolant temp sensor but you need to recalibrate the information in MS = a reflash. Not hard to do using easytherm app, a thermometer and a multimeter. Make sure the coil is disconnected before reflashing. Share this post Link to post Share on other sites
1977 ZH 540 Posted April 17, 2013 Did you read the instructions on DIY autotune? At a minimum You will need an IAT sensor. You can use your factory coolant temp sensor but you need to recalibrate the information in MS = a reflash. Not hard to do using easytherm app, a thermometer and a multimeter. Make sure the coil is disconnected before reflashing. been slowly reading through it all as I get a chance to go through it. going to try the wreckers next week for that sensor you mentioned. ill remember the disconnect the coil on reflash. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 17, 2013 going to try the wreckers next week for that sensor you mentioned. They're only $20-$30 new from Bursons/SuperCheap etc, if its the one I'm thinking of. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted April 17, 2013 Polson is correct. But you should still go to wreckers for the plug at least. that way you get a proper weatherpack. Share this post Link to post Share on other sites
1977 ZH 540 Posted April 17, 2013 They're only $20-$30 new from Bursons/SuperCheap etc, if its the one I'm thinking of. Polson is correct. But you should still go to wreckers for the plug at least. that way you get a proper weatherpack. Probably do it that way then I know the sensor wont be a dud, definitely grab the plug + some wiring from the wreckers. Share this post Link to post Share on other sites
