Mr Polson 10,214 Posted May 14, 2016 Question regarding XF/ZL heater boxes and controls. My ute currently has a ZL heater box and dash in it. I'm changing back to the standard XF GL style dash, but don't want to change the heater box, because this one works properly. Am I right in thinking you can remove the electronic components on the ZL box and so it will work with the XF cable style setup? And the other thing, how do you connect and adjust the heater control cable? I've only ever removed GL dashes, never installed one. Share this post Link to post Share on other sites
deankxf 20,292 Posted May 14, 2016 i am fairly sure the cable has a metal clip on it, that attaches it to the lever on the heater box(behind glove box) just flip it off with a screw driver(say jebus where did that go) and then the cable come out of a half threaded doover thingy.. i would assume its same heater box with electric thingys. but for about 10 bolts and 2 heater hoses(without air con hooked up) it is simple to remove when the dash it out. 2 Mr Polson and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Jiminy Kriket 133 Posted May 14, 2016 Heater boxes are identical. Pretty sure that all you need to do is as deandx said, just remove the electronic control unit and slot the cable and clip for the manual control into it. Might need a couple of goes at it to get the position of the cable right in the flap arm. 2 XTREME KARTS XF and Mr Polson reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted May 14, 2016 Might need a couple of goes at it to get the position of the cable right in the flap arm. pretty sure you just put it on full hot or full cold and flip the lever on the heater box to the extreme and clip it in. i havent done one for ages, but have an XG here i could check if you wanted to 3 steve mcqueen, XTREME KARTS XF and Mr Polson reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 15, 2016 Thanks guys. Reason I don't want to change the box is this one has the stronger metal recirc/fresh valve, and it's not broken. The GL one I have, is broken. Plus I've refoamed the ZL one that is currently in the ute. I'll see how I go with it Dean, and if I get stuck I'll ask for pics 2 XTREME KARTS XF and deankxf reacted to this Share this post Link to post Share on other sites
