Shaun Morgan 1 Posted February 20, 2016 When temp is Normal range The car loses power up hill will change back to 2nd and gutless . before it would be in 3 gear doing with power to spare got me beat Share this post Link to post Share on other sites
bear351c 10,325 Posted February 21, 2016 Fuel pump shagged, coil pack shagged, blocked fuel filter or air filter, plugs knackered, leads stuffed, cracked distributor cap, hand brake on........ 1 Stevemack reacted to this Share this post Link to post Share on other sites
Shaun Morgan 1 Posted February 22, 2016 Fuel pump shagged, coil pack shagged, blocked fuel filter or air filter, plugs knackered, leads stuffed, cracked distributor cap, hand brake on........ It starts and runs fine All the above done . temp in middle of Gauge when I have trouble ..May be Thermostat ??? .. Its had the head and rad done 1 year ago 1 Shaun Morgan reacted to this Share this post Link to post Share on other sites
MNTL.XD 3,831 Posted February 23, 2016 So it's only when going uphill? Will it do it on level ground if you floor it enough for it to drop back to 2nd? Maybe it could be a gearbox (fluid) problem? Share this post Link to post Share on other sites
Shaun Morgan 1 Posted February 24, 2016 So it's only when going uphill? Will it do it on level ground if you floor it enough for it to drop back to 2nd? Maybe it could be a gearbox (fluid) problem? LEVEL GROUND It seems to be fine .Thinking Thermostat maybe Up hill on a long pull when it dose it Share this post Link to post Share on other sites
bear351c 10,325 Posted February 25, 2016 Sounds like a problem under load.. Did you change out the fuel filter ? Or as MNTL.XD said..trans fluid level OK? Sounds like its going into limp mode. Is the NF really hot under the bonnet, maybe your gauge is out of whack, and she's overheating. Try changing the 'stat for a cooler one, or grab a second hand radiator, maybe? Is the timing correct.? Share this post Link to post Share on other sites
Shaun Morgan 1 Posted February 25, 2016 Sounds like a problem under load.. Did you change out the fuel filter ? Or as MNTL.XD said..trans fluid level OK? Sounds like its going into limp mode. Is the NF really hot under the bonnet, maybe your gauge is out of whack, and she's overheating. Try changing the 'stat for a cooler one, or grab a second hand radiator, maybe? Is the timing correct.? Radiator 8 months old .once you climb the hill all good again I will do the Themostat and temp sender unit see what Happens Thanks lads Share this post Link to post Share on other sites
