CHESTNUTXE 7,340 Posted April 29, 2020 Nah the scales are good because i weighed myself at the chemist and it was virtually the sameSent from my SM-G570Y using TapatalkOk just comparison steel chaser with 205 65 15 is 17kg simmons 8.5 with 245 tyre is 24.4kg and simmons 9.5 with 275 tyre is 25kg varkin big difference but not too bad i guess thats why older simmons are so expensive now as they are lighter than the mass produced ones in asia but a 20 " wheel has heaps of meat in it 5 inches moreSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2020 Goes to show that if those measurements are accurate, going with big diameter wheels is a step backwards in many aspectsSent from my CPH1903 using Tapatalk 2 CHESTNUTXE and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,340 Posted April 29, 2020 i would still love them on my ute,if i can find another odd 20'' even in gold just paint it. Share this post Link to post Share on other sites
CHESTNUTXE 7,340 Posted April 29, 2020 i would still love them on my ute,if i can find another odd 20'' even in gold just paint it.Hey what if i used 5mm or 10mm wheel spacer to improve offset back to +10 or +15 for the simmons ? Might even do a dummy fit today at +20 just to see if it will clearSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2020 Wheels spacers... That's a negative from me (and Mr Plod)Sent from my CPH1903 using Tapatalk 2 deankxf and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,340 Posted April 29, 2020 Wheels spacers... That's a negative from me (and Mr Plod)Sent from my CPH1903 using TapatalkIts just a shim 5mm not au adaptor anyway simmons must have a special tool to undo their nuts as i just measured them and are the same diameter as normal nut 21mm on all 3 suit ford i gunna ring them to find out about this tool or socket gerg so you reckon +20 is still ok for pre au ? Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,340 Posted April 30, 2020 Its just a shim 5mm not au adaptor anyway simmons must have a special tool to undo their nuts as i just measured them and are the same diameter as normal nut 21mm on all 3 suit ford i gunna ring them to find out about this tool or socket gerg so you reckon +20 is still ok for pre au ? Sent from my SM-G570Y using TapatalkOk the 3rd rim cant be fixed so im gunna listen to yuz and put em on e bay i rang simmons and they said that 20 + backspace is not pre au they said the wheels were probly off a skyline or something they said +20 is unmachined centre so if wanted +35 mill 15 out of it ?Sent from my SM-G570Y using Tapatalk 2 deankxf and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 30, 2020 Its just a shim 5mm not au adaptor anyway simmons must have a special tool to undo their nuts as i just measured them and are the same diameter as normal nut 21mm on all 3 suit ford i gunna ring them to find out about this tool or socket gerg so you reckon +20 is still ok for pre au ? Sent from my SM-G570Y using TapatalkI reckon it would be ok for the rear but that size on the front will probably hit the radius rod or chassis rail on full lock. It's technically illegal still due to maximum width ie: 1" more than largest wheel available OEM (7 inch so 8 is max)Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,325 Posted April 30, 2020 20" diameter look stupid on x series cars anyway. unless slammed to an undrivable level 3 CHESTNUTXE, gerg and steve mcqueen reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,340 Posted April 30, 2020 20" diameter look stupid on x series cars anyway. unless slammed to an undrivable levelPut em on gemini Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,325 Posted April 30, 2020 8 minutes ago, CHESTNUTXE said: Put em on gemini Sent from my SM-G570Y using Tapatalk 15s are too big for a gemini in My opinion (people are running 17s and bigger. looks stupid Share this post Link to post Share on other sites
