bear351c
Valve cover 'spacer plates'
Recommended Posts
Morning Ford fans, has anyone used valve cover spacer plates to raise the standard rocker covers?
I was looking at some Crane roller rockers the other day, http://www.ebay.com.au/itm/FORD-302-351-CLEVELAND-ROLLER-ROCKERS-CRANE-BOLT-ON-ADJUSTABLE-52745-16-/161552893060?hash=item259d4d8484
 and the ad states that you will need to change the rocker covers, as they dont fit under standard ones.
If I wanted to keep the standard "Power by Ford" Clevo ones, can you fit a 10mm spacer plate under them?
Share this post
Link to post
Share on other sites
I wouldn't bother with spacer plates bear, the only times I've ever had to fit non stock rocker covers to a clevo was one with a rocker girdle, I'm yet to se a set of bolt on rollers (even adjustable roller rockers as I had a set under stock rocker covers on the customline) that don't fit under the stock rocker covers 5622f69b53f251cfbcf75612a096ca00.jpg
But in saying that I've only used comp or yella terra rockers on a clevo
Share this post
Link to post
The only covers i had to modify was a set of boss style alloy covers,made by holley in the usa,many others had copys of these weiand ect,,,they had oil drippers inside the cover that needed to be ground down to fit yella terra rollers.
Share this post
Link to post
OK, thanks guys.  Just that the Crane advert states......" must change valve covers". My PowerByFord covers don't have drippers, so I'm guessing they'll fit if yours did Thom.
Yeah, I know the ones. Thanks for input.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
