bear351c 10,273 Posted October 13, 2015 Morning Ford fans, has anyone used valve cover spacer plates to raise the standard rocker covers? I was looking at some Crane roller rockers the other day, http://www.ebay.com.au/itm/FORD-302-351-CLEVELAND-ROLLER-ROCKERS-CRANE-BOLT-ON-ADJUSTABLE-52745-16-/161552893060?hash=item259d4d8484 and the ad states that you will need to change the rocker covers, as they dont fit under standard ones. If I wanted to keep the standard "Power by Ford" Clevo ones, can you fit a 10mm spacer plate under them? Share this post Link to post Share on other sites
bear351c 10,273 Posted October 13, 2015 Never mind..........Pavtek have some http://pavtek.com.au/index.php/component/content/article/7-parts-a-products/140-ford-billet-cleveland-rocker-cover-spacers Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted October 20, 2015 Also aussiespeed in south aussie make em. 1 bear351c reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted October 20, 2015 I wouldn't bother with spacer plates bear, the only times I've ever had to fit non stock rocker covers to a clevo was one with a rocker girdle, I'm yet to se a set of bolt on rollers (even adjustable roller rockers as I had a set under stock rocker covers on the customline) that don't fit under the stock rocker covers But in saying that I've only used comp or yella terra rockers on a clevo 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted October 20, 2015 The only covers i had to modify was a set of boss style alloy covers,made by holley in the usa,many others had copys of these weiand ect,,,they had oil drippers inside the cover that needed to be ground down to fit yella terra rollers. Share this post Link to post Share on other sites
bear351c 10,273 Posted October 20, 2015 OK, thanks guys. Just that the Crane advert states......" must change valve covers". My PowerByFord covers don't have drippers, so I'm guessing they'll fit if yours did Thom. The only covers i had to modify was a set of boss style alloy covers,made by holley in the usa,many others had copys of these weiand ect,,,they had oil drippers inside the cover that needed to be ground down to fit yella terra rollers. Yeah, I know the ones. Thanks for input. Share this post Link to post Share on other sites
