dogart
Can't drive in the rain.....XH windscreen motor control arm stuffed.
Recommended Posts
My wipers decided to fail whilst driving home in a downpour, lucky I was only 3km away!
Ends up being the 2.5 inch control arm that comes off the wiper motor and links up the control arms.
The bolt/ball ends are F'ed rusted and rounded so it didn't hold the plastic last connector for the wiper
control arm. So it just fell off and the second control arm followed.
Now I've rung 6 wreckers here in Perth, sorry me not got.
Can't get the little control arm by itself or a complete windscreen wiper assembly!
Any McGyver fixes for this, anyone in Perth know of a XH being wrecked (have looked on gumtree, nup!)
Can't drive in the rain without bloody wipers!
Have found exactly what I want for a bargain price on ebay but won't ship to Perth for me.
http://www.ebay.com.au/itm/Ford-Xf-Nl-Xg-Xh-Wiper-Motor-Unit-Complete-/251911825421?
cheers
Share this post
Link to post
Share on other sites
My control arms and those white grommets are fine on mine.
It's the small control arm that is on the back of the motor which is stuffed rounded off!
Where one wiper control arm slips onto and the other wiper control arm clicks onto the end (The grommet in the photo with the half round end!)
Share this post
Link to post
Got the arc welder out and tried to put some more meat on the end ball.
Worked for about 10 oscillations . . . then it fell off! Just not holding. Any tighter and it would scrape out the inner plastic surface very quickly.
Time for a beer!
Share this post
Link to post
FFS, LOL! that's what happens to all of them. ^_^
The nylon cup in the socket of the end wiper linkage wears, so the arm just falls off eventually.
A pair of the new/reproduction wiper linkages will solve the issue.
They are a tight click on fit, and have a small void inside them, which holds grease for lubrication.
Don't go ruining the ball end (which is Nickel plated) by welding it, unless there are sections of the ball obviously missing, from bad rust.
And yes, with the exception of the plug being different on the XD wiper mechs, they are all the same, right up to XH.
Share this post
Link to post
That was exactly the case, it was so bad from rust and sections missing
that's why I started to rebuild with the welder.
Share this post
Link to post
Should be able to get another one of those in reasonable nick.
Failing that, try de-rusting it in a phosphoric Acid based solution.
You should be able to repair that with lead loading, and reshaping I reckon.
Share this post
Link to post
Too hard mate I'm busy working!
Called 6 wreckers here in Perth nobody has that part
and I was told that why would a wrecker take that piece off to sell
and render a complete unit useless!
Share this post
Link to post
You won't have a choice, if you want working windscreen wipers.
Look at it this way......
It'll be good for another 200 odd thousand k, after you've fixed it.
Most second hand unit's will be the same on that ball,
and/or have worn nylon sockets on the linkage arms.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
