XF001 93 Posted February 16, 2015 Does any one know how to remove the plastic moulds around the rear screen in an XF ute. Tried prying them off with a flat head screw driver and can't budge them. Thanks in advance Share this post Link to post Share on other sites
bigpaulo 239 Posted February 16, 2015 I just did this, massive job! First, remove the rear window. Take it right out. Next youve gotta try and peel the headlining back away from the rear window. Its probably gonna be glued along the rear edge, so you have to try and break the adhesive without breaking the headlining. Also completely remove your interior light. It might also help to remove your rear vent window rubbers, and c pillar trims just so you can peel the headlining back far enough. Once the headlining is back, if you reach up and feel along the top of the rear window you will feel 4 threads with nuts on poking through into the cab. Undo these nuts and the top trim will be loose. The same applies for the side plastics, there are two threads on each one that poke through into the cabin. Hope this helps. Good luck! 2 Outback Jack and steve mcqueen reacted to this Share this post Link to post Share on other sites
XF001 93 Posted February 17, 2015 Thanks bigpaulo. Didn't think it would be too easy. Luckily, the rear window has to come out anyway to remove some rust and the rear vent windows are easy to remove. 2 bigpaulo and Outback Jack reacted to this Share this post Link to post Share on other sites
bigpaulo 239 Posted February 17, 2015 When you put it all back together you'll need to get some contact adhesive and glue the headling back along the ridge in the window. Otherwise when you put the window back in its liable to push the headlining down. just a handy tip! 1 Outback Jack reacted to this Share this post Link to post Share on other sites
