FAT245
AU Falcon V8 ECU Reflashing
Hey Guys,
I have been wondering if there is any need for a reflashing service to flash an AU V8 EEC with Specific Settings to aid Conversions?
I know that you can buy a chip for it, and this is a good Option if you want to mod the motor and tune it, but some guys just want to install a stock motor and cruise..
I can do Most (If not all) AU V8 EECs
Convert Manual to Auto
Convert to Different Automatic Types E.g. C4 or other Non Electric Boxes (This helps with Idle Control)
Remove Speed and RPM Limiters
Disable ABS / Traction Control
Disable Torque Modulation
Disable Fault Codes
Enable or Disable EDIS
Enable or Disable Adaptive Shift
Enable or Disable Smartlock
Enable or Disable Smartshield
Enable or Disable HEGO Sensors
These are just some of the settings which I have access to.
Let me know your opinions...
Nathan
I think it's a great idea. I just found a advert here in NZ where a guy is doing the same but with the LS engine ecu and loom, turns it into a 5 wire hook up that any person with basic car knowledge can install.
If you could do that so its plug and play, make life very easy for people.
