Ando81 2,949 Posted June 15, 2014 Hi lads, as the title suggests, I'm experiencing poor fm radio reception in my ute. I had a CD player fitted a while ago but the radio was crap before then. I shouldn't have been so tight and got the aerial replaced at the same time but didn't. The steel part of the original aerial is bent and has a small kink in it. Was wondering if I mounted a new base and aerial on the guard would it improve signal without running the cable right back to the CD player. I'm told that my ute being a 91 model will have a pull apart join in the coax cable that I can access in the inner guard. Fire away with your opinions of best solution please!! Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 15, 2014 Just buy one of these. I have 2, one in my shed hooked up to my CD player out there, it works perfect i get heaps of stations and i have one for PG. http://www.ebay.com.au/itm/260881983890?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649 1 PH351 reacted to this Share this post Link to post Share on other sites
PH351 314 Posted June 15, 2014 I bought similar off ebay. Mine is a little black one you mount to the windscreen. It also has a 12v wire. Haven't tried it yet but not paying 100+ dollars that normal guard mount universal aerials seem to be at retail shops. Share this post Link to post Share on other sites
hendrixhc 10,921 Posted June 15, 2014 Thanks Steve been looking for one of those! 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted June 15, 2014 So without sounding stupid, can that aerial be mounted inside the car anywhere and get reception? Or does it need to be stuck onto the glass or something. Pics don't really show much I'm sorry. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 15, 2014 Mine in the shed, still has the cable ties around it and sits just behind the unit. I was thinking when i got mine "how is this gonna work?" But it does, i just plugged it in and presto. Ill do the same in PG when its time. Share this post Link to post Share on other sites
Ando81 2,949 Posted June 15, 2014 Sounds too easy! I'll get one and give it a try, cheers for the tip 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
