Jkmacxf 24 Posted June 1, 2014 G'day ozfalconers, xf fairmont ghia indicator lights come on in the dash with headlamps on. Has anyone else had or heard of this drama. Bad earth maybe? Look forward to hearing your thoughts. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 1, 2014 I had an similar issue, was bad connections to the battery posts, got new terminals and that fixed it. 1 Jkmacxf reacted to this Share this post Link to post Share on other sites
Jkmacxf 24 Posted June 1, 2014 I had an similar issue, was bad connections to the battery posts, got new terminals and that fixed it. Thanks, for that Mr Polson the negative terminal had a cover on it, I removed it & there is corrosion everywhere. In the process of replacing terminals & tidying the wiring up. Hopefully should fix it. Cheers 1 Mr Polson reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted June 1, 2014 pour some water on it to do a quick check. probably need a new battery soon bruz. it may be leaking around the terminals 1 Jkmacxf reacted to this Share this post Link to post Share on other sites
Jkmacxf 24 Posted June 12, 2014 All good oz falconers replaced the negative battery post clamp & a new earth lead to the block because it was all corroded up the middle. Trip computer and everything started working again. 4 Ando81, Mr Polson, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
