90XFUTE 0 Posted October 29, 2013 a few months ago i was changing into 2nd and the clutch cable snapped, I put a new one on got it all nice and it ran good til a few weeks ago it became loose so i've tightened it heaps and its still fucks up, now the pedal is sitting of the left a bit and it has a lot more movement that it use to. i cant seem to get it in any gear unless it jammed up against the fire wall, has anyone had this problem before or does anyone have any idea what might be going wrong? Share this post Link to post Share on other sites
dusty_ben 143 Posted October 29, 2013 Sounds like the pin in the side of the pedal box has cracked the pedal box. Very common on x series and e series. Pull pedal box out. Realign pin and weld it back together. Then plate the shot out of the back of it. 1 Stevemack reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted October 29, 2013 have a look at where the clutch pedal mounts under the dash, its probably cracked. sometimes the firewall cracks also, but seeing the pedal is off skew it will be the pedal box i think. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
90XFUTE 0 Posted October 29, 2013 ok, i see what ya mean, i might see if i cant get a pedal box or whole new pedal from the wreckers coz i cant weld, cheers guys Share this post Link to post Share on other sites
deankxf 20,288 Posted October 29, 2013 its not the pedal its the bit it mounts to. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
dusty_ben 143 Posted October 29, 2013 Pull the pedal box out. It's not to hard on x series. Drop steering colum. Unbolt. Think its four from cab side and brake booster bolts. And take it to a small welding engineering place. Prob cost a box of piss. Pedal should be fine. Another place to go would be a decent exhaust shop. They always have migs and like cashies. HahA Share this post Link to post Share on other sites
