mcfly94
Zl heater box working XE dash? (Air con switch/Vac lines)
Recommended Posts
fitting a clevo to an xf is easy ,couple tricks die grind the engine mount plates, bolt holes 15 mils at the rear of all 4 holes ,then die grind the chassis hole 15mils at the front of each hole, with the heater pipes either pull then up and to the left without snapping them off ,or get the outlets modded at a radiator shop
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
