Ronnie789 4 Posted January 30 Hey all, I've got an XD was 250 but converted to 351c, trying to sort the tacho wiring, everything seems to point to pink and blue wire to the coil negative, but the pink and blue wire is on the coil positive. does that seem right. Engine is from 77 Fairlane but has electronic ignition, not sure if that's original or has been grafted in somehow. the whole engine and trans wiring job is pretty average, not sure what's been hacked and what hasn't. Thanks 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,420 Posted January 30 Think its white/green trace....? Neg side of the coil. Share this post Link to post Share on other sites
gregaust 334 Posted January 30 Usually the pink/blue to negative 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,972 Posted January 30 Base model may not have the wire either. I had to run one in My Dad's XE when I fitted an s pack cluster. Negative coil and I may have joined a wire to the cluster for it even(not in the socket for cluster either) Share this post Link to post Share on other sites
Ronnie789 4 Posted February 4 Thanks all, will the engine run if the coils wire arse about, seem to remember from trade school that of would but that was a long time ago, memory is a bit foggy now. It's a six cylinder tacho so I think it might have been original, tried the trimpot and other methods mentioned on here to change from 6 cyl to 8 but still doesn't work. Just trying to decide it it's a wiring issue or the tach. Guess I could always run a wire from the coil neg straight to the tacho and find out that way. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,972 Posted February 4 56 minutes ago, Ronnie789 said: Thanks all, will the engine run if the coils wire arse about, seem to remember from trade school that of would Pretty sure they do run like this. But not sure if there's any issues from it? Share this post Link to post Share on other sites
gregaust 334 Posted February 4 Have seen them run with coil wires reversed 1 deankxf reacted to this Share this post Link to post Share on other sites
