jamie247 542 Posted July 26, 2023 Hi lads , got an EF XR6 3.45 and driveshaft, what needs doing to fit to xe, trailing arm bush to e series diff end, everything thing else should bolt in i was told, what can be done with handbrake as the whole brake system/calipers is way different to x series Share this post Link to post Share on other sites
deankxf 20,292 Posted July 26, 2023 30 minutes ago, jamie247 said: Hi lads , got an EF XR6 3.45 and driveshaft, what needs doing to fit to xe, trailing arm bush to e series diff end, everything thing else should bolt in i was told, what can be done with handbrake as the whole brake system/calipers is way different to x series if you can run the brake lines on the XE to how they are on the EF that's one way, or you can do them on the diff similar to the XE XF way also seen it done both ways, (no pics handy) and the EF lines on the XE looked easier handbrake you'd be best getting a new one custom made, back in the day (20yrs ago) i was quotes $120 from ABS brakes to make one, these days you'd be surely double that if anyone has the brains to do it. you can cut and join the cable with cable clamps and make a hybrid of the 2 in the short term and prove it works before getting the cable made up also. tailshaft will fit if it's a sedan XE and Sedan (not fairlane/LTD) EF (would be if XR6 sedan, not if wagon ) Share this post Link to post Share on other sites
jamie247 542 Posted July 27, 2023 16 hours ago, deankxf said: if you can run the brake lines on the XE to how they are on the EF that's one way, or you can do them on the diff similar to the XE XF way also seen it done both ways, (no pics handy) and the EF lines on the XE looked easier handbrake you'd be best getting a new one custom made, back in the day (20yrs ago) i was quotes $120 from ABS brakes to make one, these days you'd be surely double that if anyone has the brains to do it. you can cut and join the cable with cable clamps and make a hybrid of the 2 in the short term and prove it works before getting the cable made up also. tailshaft will fit if it's a sedan XE and Sedan (not fairlane/LTD) EF (would be if XR6 sedan, not if wagon ) Was thinking getting new brake lines made up and just attach front xe cable to ef cable hopefully it'll be all good 1 deankxf reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted July 27, 2023 21 hours ago, deankxf said: if you can run the brake lines on the XE to how they are on the EF that's one way, or you can do them on the diff similar to the XE XF way also seen it done both ways, (no pics handy) and the EF lines on the XE looked easier handbrake you'd be best getting a new one custom made, back in the day (20yrs ago) i was quotes $120 from ABS brakes to make one, these days you'd be surely double that if anyone has the brains to do it. you can cut and join the cable with cable clamps and make a hybrid of the 2 in the short term and prove it works before getting the cable made up also. tailshaft will fit if it's a sedan XE and Sedan (not fairlane/LTD) EF (would be if XR6 sedan, not if wagon ) Driveshaft is xr6 sedan EF 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted July 27, 2023 4 hours ago, jamie247 said: Was thinking getting new brake lines made up and just attach front xe cable to ef cable hopefully it'll be all good the handbrakes only differ due to the EF having the hand brake mounted next to the console from memory. the only one i remember seeing the person cut the cables about where the back of the fronts seats would be and joined there with cable joiners. you'll soon see what's needed once you mount it up as much as you can Share this post Link to post Share on other sites
jamie247 542 Posted July 28, 2023 21 hours ago, deankxf said: the handbrakes only differ due to the EF having the hand brake mounted next to the console from memory. the only one i remember seeing the person cut the cables about where the back of the fronts seats would be and joined there with cable joiners. you'll soon see what's needed once you mount it up as much as you can Yep considering the amount of modded cars i think a handbrake cable is the least hurdle to combat lol 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 29, 2023 ive also heard use a AU watts link arms as it bolts more to the centre of the diff cover of coarse you need the diff cover as well,anyone else no about this. Share this post Link to post Share on other sites
deankxf 20,292 Posted July 29, 2023 49 minutes ago, CHESTNUTXE said: ive also heard use a AU watts link arms as it bolts more to the centre of the diff cover of coarse you need the diff cover as well,anyone else no about this. i think the mounting point for watts link is lower on the AU diff, which better suits the XE XF watts link when you lower the car. (don't think the arms themselves are swapped) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 29, 2023 Yes something like that I read somewhere,maybe I will try that when I do springs on my car.also what if the ef has the balancer on the shaft ? 1 Farkin351 reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted July 29, 2023 42 minutes ago, CHESTNUTXE said: Yes something like that I read somewhere,maybe I will try that when I do springs on my car.also what if the ef has the balancer on the shaft ? pretty sure i've used them as is. i didn't notice any difference but panko said it was better with it in his XF Share this post Link to post Share on other sites
