Grr351 4 Posted May 22, 2023 Hi I have my single rail out of my falcon and would like to replace the selector shaft seal ,what's involved in doing this ? 1 , remove the six 7/16 bolts from the extension housing which I have done ,how do I pry the extension housing off ? And anything else I need to know ? PS also I will replace the extension housing gasket also ,does this gasket need sealer on both sides ? Thanks in advance Share this post Link to post Share on other sites
deankxf 20,292 Posted May 22, 2023 1 hour ago, Grr351 said: Hi I have my single rail out of my falcon and would like to replace the selector shaft seal ,what's involved in doing this ? 1 , remove the six 7/16 bolts from the extension housing which I have done ,how do I pry the extension housing off ? And anything else I need to know ? PS also I will replace the extension housing gasket also ,does this gasket need sealer on both sides ? Thanks in advance when i did mine about 20yrs ago, i'd have used aviation gasket cement on both sides of the gasket (paranoid) yeah nothing is holding it on other than the roll pin on the selector shaft to the gearstick housing otherwise. i'd remove the speedo drive just to be sure it doesn't snag on something. (if it's XD XE XF etc. prior will be cable and needed removing to get the box out of car) it might have dowel pins, that are keeping it tight on the box i can't remember. Share this post Link to post Share on other sites
dvfalcon 352 Posted May 23, 2023 you will most likely find the selector shaft is worn. they all are. 20 years ago i would change out a single rails on a regular basis to 2 reasons . selector rail shaft or ir the notch in the selector fork. speedo sender out remove the roll pin from the selector take off remote and ext housing Dale 1 deankxf reacted to this Share this post Link to post Share on other sites
