Meady 0 Posted August 26, 2021 seeking advice re: putting a xf fuel tank into a xc v8 ute , xf sender has a 3 pin female on top of sender where xc has only one pin ? any advice on how to wire this . Xf tank has a fuel return line [ fuel injected tank ? ] are sender and xc gauge compatable ? Share this post Link to post Share on other sites
gerg 10,875 Posted August 26, 2021 They aren't compatible. Up to XC were resistance type with a pivoting float, XD-XF were inductance type (no moving parts). The electronics are completely different between the two so unless the senders can be swapped, sounds like you're in a bit of a pickle. There was someone on here making a conversion box just as a bit of a project, but that sounds like more trouble than it's worth.Sent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
gerg 10,875 Posted August 26, 2021 Here we go...@Crazy2287 was the onehttps://r.tapatalk.com/shareLink/topic?url=http://www.ozfalcon.com.au/index.php?/topic/7595-diy-fuel-sender-conversion-for-factory-x-fal-cluster/&share_tid=7595&share_fid=64023&share_type=t&link_source=appSent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
Meady 0 Posted August 27, 2021 alright how about using a aftermarket fuel gauge ? any info on this idea as the xf fuel tank is the best tank i have or any body got a good xc ute tank they would part with ? Share this post Link to post Share on other sites
Crazy2287 1,889 Posted August 31, 2021 install a float type sender? Share this post Link to post Share on other sites
