David seagull 9 Posted March 4, 2021 When the motor is coldit doesn't want to idle After its warmed up yer no problems it idles at 500 when warm and I can't find any vacuum leaks ,Intake manifold it tight With the aircon on it doesn't change much The battery has been out is there something I should reset??? 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 5, 2021 When the motor is coldit doesn't want to idle After its warmed up yer no problems it idles at 500 when warm and I can't find any vacuum leaks ,Intake manifold it tight With the aircon on it doesn't change much The battery has been out is there something I should reset???Idle is too low mate.If manual should idle about 700rpm when at operating temp.When it's cold and warming up, idle speed controller should have it idling around 750-800rpm.The idle speed controller is on top of the throttle body, just make sure you haven't knocked the electrical connector and unplugged it.Sent from my S21 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
David seagull 9 Posted March 5, 2021 Cheers outback Jack It is plugged in but the clip is broken If it plugged in does it need a clean can it be cleaned or swap out? 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 5, 2021 Cheers outback Jack It is plugged in but the clip is broken If it plugged in does it need a clean can it be cleaned or swap out?They can be cleaned with carby/throttle body cleaner, take off spray it in the two holes and turn upside down to empty it out. The Idle Speed Controllers are pretty durable. Goss do a decent replacement if you need one. If the clip is broken on the wiring loom side, just use run of the mill connectors until you can source a new plug.If it's broken on the ISC side, get one from the wreckers or buy a new one. If you don't want to spend money, just use spade connectors and fix the s*** connection.If you want new connectors try eBay or PEC. Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
David seagull 9 Posted March 5, 2021 Cheers Ill give it a go or get another one 1 Outback Jack reacted to this Share this post Link to post Share on other sites
David seagull 9 Posted March 8, 2021 Thanks outback Jack It runs like a dream now Thanks for your help 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 8, 2021 Thanks outback Jack It runs like a dream now Thanks for your helpNo probs mate. Gotta keep the good ol falcons going. Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
