David seagull
Idling ??? Xh 4.o Longreach
When the motor is coldit doesn't want to idle
After its warmed up yer no problems  it idles at 500 when warm and I can't find any vacuum leaks ,Intake manifold it tight
With the aircon on it doesn't change much
The battery has been out is there something I should reset???
Idle is too low mate.
If manual should idle about 700rpm when at operating temp.
When it's cold and warming up, idle speed controller should have it idling around 750-800rpm.
The idle speed controller is on top of the throttle body, just make sure you haven't knocked the electrical connector and unplugged it.
Sent from my S21 using Tapatalk
Cheers outback Jack
It is plugged in but the clip is broken
If it plugged in does it need a clean can it be cleaned or swap out?
They can be cleaned with carby/throttle body cleaner, take off spray it in the two holes and turn upside down to empty it out.
The Idle Speed Controllers are pretty durable. Goss do a decent replacement if you need one.
If the clip is broken on the wiring loom side, just use run of the mill connectors until you can source a new plug.
If it's broken on the ISC side, get one from the wreckers or buy a new one.
If you don't want to spend money, just use spade connectors and fix the s*** connection.
If you want new connectors try eBay or PEC.
