superyob 270 Posted December 18, 2020 Not sure if this is in the right section but my BF ute always fills up with water on the passenger side after a good downpour. So I went searching for water entry points and found a couple of holes in the A pillar seams (under the rubber strip) whereby a piece of wire passed straight through. See attached pic. I have sealed it with a length of duct tape and if that works, I'll run a bead of sealer along the seam for a more permanent fix... 1 1 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted December 18, 2020 good chance that's where it's getting in, water can get through smaller than what you'd get a piece of wire through even. i'm not familiar with these newer models, so that's interesting to learn Share this post Link to post Share on other sites
superyob 270 Posted December 18, 2020 Yes, I thought it may be handy info for those who have later model Falcons as well... 1 deankxf reacted to this Share this post Link to post Share on other sites
superyob 270 Posted December 21, 2020 Well, it poured down last night. And no water in the cab... 1 1 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted December 21, 2020 47 minutes ago, superyob said: Well, it poured down last night. And no water in the cab... good to know, wish they were all this simple Share this post Link to post Share on other sites
