Outback Jack 4,823 Report post Posted October 4, 2020 How you going with it@wokko , success yet?Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
wokko 21 Report post Posted October 7, 2020 Just an update, I had to wait for the weather to clear up (no luxury garage ), I pulled the rad and then balancer/timing cover off and realigned to tdc which the mark on the pulley was about 30 mm out so outback jack was correct around 12 o'clock was good I put it all back togther with new timing cover gasket/seal and said a few hell marys and turn the key and it purred like a cat warmed it up and put it into timing mode which took a few goes (knew something was going to go wrong it was going too well ) Set it to 5deg and through some 98 fuel it it and it is like a new motor. Cheers and thank you fro everyones help 2 Outback Jack and macman reacted to this Share this post Link to post Share on other sites
Outback Jack 4,823 Report post Posted October 8, 2020 Good stuff Wokko, glad it came good for you. Base timing is 10 degrees BTDC. So you may have it a bit retarded.You should notice a difference again from changing that.So happy for ya mate .I love it when a plan comes together!Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
