Jack major 2 Posted February 11, 2020 Just wondering if I’d be able to pull the manual box outta my au xr6 and put it into my ba xr6 and if so what is required to do so Share this post Link to post Share on other sites
Thom 6,710 Posted February 12, 2020 If the ba is already equipped with a 5 speed manual and you just want to swap a broken or worn out t5 for a better one, externally Au an ba t5's are the same so that would be pretty easy, if you are talking about putting the 5 speed in an automatic ba, all you can use from the au is the gearbox, clutch and flywheel, the pedals, bellhousing, ecu, consoles all don't fit ba and the biggest difference is Au use a cable clutch setup and ba use a hydraulic clutch 1 gerg reacted to this Share this post Link to post Share on other sites
