XRWagz 34 Posted September 16, 2019 A friend is dropping a 86DA crossflow from an XF into his XD and has discovered the flywheels are different. Does anyone know if a flywheel from an EA will bolt up to a late XF? Share this post Link to post Share on other sites
deankxf 21,128 Posted September 16, 2019 the XF 86DA flywheel will have the same bolt hole size as the EA.. the XF flywheel can be drilled out to the bigger size the XD has, they are otherwise identical to XD etc(probably same as XA or even older) Share this post Link to post Share on other sites
XRWagz 34 Posted September 16, 2019 Theres the catch, the XF motor was bolted up to an auto.... So the EA flywheel can be used on the XF motor? Share this post Link to post Share on other sites
deankxf 21,128 Posted September 16, 2019 1 minute ago, XRWagz said: Theres the catch, the XF motor was bolted up to an auto.... So the EA flywheel can be used on the XF motor? i think they are same also, they must be because i used an EA auto and torque converter on my XF ute. 1 XRWagz reacted to this Share this post Link to post Share on other sites
