El Dee 3 Posted August 3, 2019 Hi Im wondering if theres any screw or knob or something on the XF S-pac cluster you can turn to adjust the speedo reading. Speedo was reading 20km over however I installed the correct driven gear for a 3.23 diff ratio and its now reading 10km under, Im guessing because the tyres Im running now are larger than stock, just need to get that little nudge up and shes ready for RWC Share this post Link to post Share on other sites
deankxf 20,290 Posted August 3, 2019 for 10% you can go about 1 tooth difference on the gear for.. i assume you went from 19tooth to 21? if you get a 20 tooth t will be about right. for anything in between if you pop the needle off and preposition it slightly over or under at ZERO it will give you a simple adjustment. i think there is a trim pot on them you can adjust, but from memory it might be painful to access. you can also do it with an electronic speedo corrector kit.. shouldn't be required for what you have though Share this post Link to post Share on other sites
El Dee 3 Posted August 3, 2019 8 hours ago, deankdx said: for 10% you can go about 1 tooth difference on the gear for.. i assume you went from 19tooth to 21? if you get a 20 tooth t will be about right. for anything in between if you pop the needle off and preposition it slightly over or under at ZERO it will give you a simple adjustment. i think there is a trim pot on them you can adjust, but from memory it might be painful to access. you can also do it with an electronic speedo corrector kit.. shouldn't be required for what you have though Another $40 for a new gear is what I was trying to avoid but I think thats the go and yeh good idea with adjusting the needle thanks for the tip! Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted August 3, 2019 what size tyre are you running Share this post Link to post Share on other sites
El Dee 3 Posted August 3, 2019 31 minutes ago, CHESTNUTXE said: what size tyre are you running Was running 19 tooth changed to 21 tooth to suit 3.23 diff but im guessing the bridgestone eagers on the 14" rims are larger than stock so still out of whack. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted August 3, 2019 ok but what tyre ? 235 ? Share this post Link to post Share on other sites
El Dee 3 Posted August 3, 2019 33 minutes ago, CHESTNUTXE said: ok but what tyre ? 235 ? Yeh pretty sure its 235/60/14 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted August 3, 2019 should be fine,belive it or not there is 2 types of green 21 a dark and light,a 20 is for 3.08 ratio and is brown. Share this post Link to post Share on other sites
deankxf 20,290 Posted August 4, 2019 5 hours ago, El Dee said: Another $40 for a new gear is what I was trying to avoid that 21 tooth gear is quite often used, you'd probably be able to sell it for $20 easy enough at min(or $35 incl post perhaps?) i had 235/60/14s on my cars and it actually removed the factory speedo error with the 2.77 or 2.92 diffs.(used the wheels on several cars) the tyre size will be a small percent difference, like 3 or 4 i think over"correct" sizing of tyre. i never went by colours of the gears, just need to make sure it's the correct one for the gearbox in my opinion(borg warner 4 speed auto or C10/fmx etc) i've seen varying colours with the same teeth and angle in the past. Share this post Link to post Share on other sites
