xwagon 168 Posted June 2, 2019 Hey guys, looking at importing in a mcdonald engineering bolt in 4 link setup, main reason as i cant find a set of xw/y leaf springs in new zealand. Does anybody run these in their falcon? Share this post Link to post Share on other sites
slydog 7,874 Posted August 11, 2019 Sorry didn't see this post. I do use basically a McDonald Bros tri angle kit in my ute but weld in style. It runs double adjustable viking coil overs front and rear with a Comp Enginerring adjustable anti roll bar. I can lower or raise the car while keeping spring rate the same on the rear in like 5mins each side. But the shocks allow you to get the ride exactly as you want. Running a soft 150lb spring leaves the shock to control ride alot better than a conventional set up. Share this post Link to post Share on other sites
