Mark Bretherton 26 Posted March 25, 2018 Trying to fit xg sway bar around au block .Lowering not a problem extending 3 mls forward is.If I cut rods that connect sway bar to lower conrol arm and overlap them and weld together it will give me approximatly 3 ml But is it legal and will it work? Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
Thom 6,654 Posted March 25, 2018 Trying to fit xg sway bar around au block .Lowering not a problem extending 3 mls forward is.If I cut rods that connect sway bar to lower conrol arm and overlap them and weld together it will give me approximatly 3 ml But is it legal and will it work? Sent from my HUAWEI Y360-U03 using Tapatalk Space the sway bar itself down using some spaces, should get you out of trouble Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 25, 2018 Space the sway bar itself down using some spaces, should get you out of trouble Yes I did that and if I jack it up the sway bar hits sumpAnd sway bar sit on angle whilst sitting normally .Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
Thom 6,654 Posted March 25, 2018 Yes I did that and if I jack it up the sway bar hits sumpAnd sway bar sit on angle whilst sitting normally .Sent from my HUAWEI Y360-U03 using TapatalkYou don't want to weld suspension components it's illegal without having an engineers certificate Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 25, 2018 You don't want to weld suspension components it's illegal without having an engineers certificate OK thank you I'll leave it Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted March 25, 2018 Without being able to look at it, I'd suggest copying the idea of Commodore S-shaped links. They were introduced to (attempt to) correct a geometry problem that chewed out bushes very rapidly. You could tweak yours a tad with a little kink at each end to get the offset you need. Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
Mark Bretherton 26 Posted March 26, 2018 Without being able to look at it, I'd suggest copying the idea of Commodore S-shaped links. They were introduced to (attempt to) correct a geometry problem that chewed out bushes very rapidly. You could tweak yours a tad with a little kink at each end to get the offset you need. Sent from my CPH1607 using TapatalkDo you know what year or model so I can do wrecking yard crawl.Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
