Mark Bretherton
Sway bar fitting
Trying to fit xg sway bar around au block .
Lowering not a problem extending 3 mls forward is.
If I cut rods that connect sway bar to lower conrol arm and overlap them and weld together it will give me approximatly 3 ml
But is it legal and will it work?
Sent from my HUAWEI Y360-U03 using Tapatalk
Space the sway bar itself down using some spaces, should get you out of trouble
Yes I did that and if I jack it up the sway bar hits sump
And sway bar sit on angle whilst sitting normally .
You don't want to weld suspension components it's illegal without having an engineers certificate
Without being able to look at it, I'd suggest copying the idea of Commodore S-shaped links. They were introduced to (attempt to) correct a geometry problem that chewed out bushes very rapidly. You could tweak yours a tad with a little kink at each end to get the offset you need.
Do you know what year or model so I can do wrecking yard crawl.
