CHESTNUTXE
6cyl c4 casefill
46 posts in this topic
I've got a same date coded C6DP, Z servo, 24/24 spline, I was told it came from a mustang 200ci 6, has from what I have figured out to be a small pattern 6cly alloy bellhousing, Has FoMoCo in oval instead of FORD,
Will have to check date rings thanks Greg.
I HAVE sourced a pan fill c4 an aussie one out of a f truck 1970s says d7 .
I got this c4 she is a 11/80 build 0acd8fc8e1ceb3dcfbd95b740117d3a2.jpg37857073e2108b5e09dbd3a74c1fe3a6.jpgd5824c346063045584302bf551a5736c.jpg
Sent from my SM-G570Y using Tapatalk
Yep nice .... Definitely a late one . Does it happen to have a deeper pan or just normal? Reason I ask is there is also an odd C5 valvebody.
That one should have the fine thread front band adjuster and the larger cooler fittings
CHESTNUTXE likes this
ok i will check the pump bolt length.
Spot on greg the bell bolts are too short5df5343fa7dce96228e26ffee80a003a.jpg
can anyone tell me is the speedo transducer the same as the common borgwarner ones just with a different length plastic cog ?
Yep thats what i figerd also i have heard there is 2 different types of panfil dipstick tubes and sticks is this true
