CHESTNUTXE 7,311 Posted June 17, 2017 This has been bugging me for while and nobody can seem to tell me,when using a c4 on a crossflow street/strip,are people using the pre 1970 box with the smaller input shaft and just beefing up the box or using the later post 1970 box with the larger spline,reason i ask this is i dont see any aftermarket bellhousings for a 250 to suit the later box ?,or is the earlier windsor style box up to the task once prepped,i have found in america a few c9 alloy bells to suit 200 c.i but the starter sits way down compaird to our aussie engines,from what i have found the xd (taxi c4) is a good choice altho its still the earlier design,and the bell is cast iron like all the 6cyl bell's. Share this post Link to post Share on other sites
gregaust 319 Posted June 18, 2017 Only use the 70+ trans . They are better all round. The correct bellhousing is cast iron. You can use that bell on any later trans, only difference if you use a clevo pan fill type case is there will be a flange sticking out around the back of the bellhousing Look for a trans case , dipstick in case , breather on top of extension housing. Will have the larger 26 spline input shaft, if unsure measure it , will be 0.839" diameteThay are out there although rareĀ Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted June 18, 2017 ok i was under the impression that the cast iron bell only fits the early box's as i have had a look at a few different box's. Share this post Link to post Share on other sites
